Y(t) Plotter
Y(t) Plotter
Beitrag von abacom » Montag 13. Oktober 2008, 11:29
p.erasmus
Anmeldungsdatum: 15.01.2007
Verfasst am: 23.07.2007 20:57 Titel: Y(t) Plotter
Hello to all
I have a strange problem with the Y(t) plotter before the last update I was able to set the range and when running the application in the debugger mode I would have the scales as I preset the range now I can set the range and when the application runs the scales always go back to the default -10 to 10 mv
do i do something wrong or is there a problem
Thanks
Peter
_________________
P.Erasmus
Automotive Engineering
http://www.wenko.ch
Switzerland
Verfasst am: 23.07.2007 21:02 Titel:
Behavior depends on front panel property "remember last setting".
p.erasmus
Verfasst am: 24.07.2007 16:27 Titel:
Dear Abacom
The remember last setting in the front panel properties are clicked
and the problem are the same
Regards
Peter
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
Verfasst am: 24.07.2007 17:05 Titel:
Range settings belong to "remembered" settings. If "remeber" is checked as in your case, you need to change settings in RUN mode. On next start they will be remebered, which neccessarily means that settings made in edit mode are overwritten. Same behavier as switches, potis, etc. Nothing "strange" with that.
p.erasmus
Verfasst am: 24.07.2007 18:28 Titel:
Abacom
Thank you it is working now my mistake
Best Regards
Peter
