Format of Table values
Beitrag von abacom » Dienstag 30. September 2008, 11:06
p.erasmus
Anmeldungsdatum: 15.01.2007
Verfasst am: 27.01.2007 06:44 Titel: Format of Table values
Hello
Could you please inform me of the format of the data in a Table.
Is the data which is in the table in in ASCII or Binary ,before it gets exported to *TXT file of Excel.Is the data Tabulator or comma seperated?
I export the values in a table to an excel File and then I import it to Diadem (National Instruments Report and analysis Software) With Diadems excel import function .The actual data imports correctly
however the timestamp is in correct .
If I know the raw data type I can import it with the correct Diadem Plug in.
I use the recorded table data for analysis of the operation of a system
Best Regards
p.erasmus
_________________
P.Erasmus
Automotive Engineering
http://www.wenko.ch
Switzerland
ExpertProfi
Anmeldungsdatum: 20.08.2006
Verfasst am: 27.01.2007 19:43 Titel:
Simply open the file with an editor (notepad), and you´ll see it´s ASCII, separated with ";" !
ExpertProfi
p.erasmus
Verfasst am: 27.01.2007 22:02 Titel:
Thank you for your reply
Regards
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
