Dual Power Supply -12V GND +12V
Verfasst: Dienstag 30. Oktober 2018, 17:13
A very simple, but very usefull dual power supply.
Output is -12VDC GND +12VDC and 12VAC GND 12VAC
Other voltages are possible when you alter the transformer and the voltage regulators.
The transformer voltage should be approximately equel to the voltage regulator output.
I use the AC outputs to test other power supplys.
