Pokeys 56U, USB version
TOURNEUR
Beitrag von TOURNEUR » Samstag 28. Februar 2015, 16:15
Hello everybody ,
I have used , the TCP version of Pollabs ,and want to use the usb version .
But in Profilab ,I see no example for usb version .
"We have this thing for some time as a pattern. At first glance, we liked this also good. Also a second look rather less. 1.) Unfortunately, the device is a specific version of .NET advance. I myself have used .NET days to install so that the device worked. 2.) The software interface is poorly documented and used a huge overhead. In view of this, we are of this unit do not put your finger. I'm sorry. Alternatives are plentiful.
_________________ ABACOM support
Since 2009, could we see, the compatibility possible with the new version, Pokeys 56U ?
Or does this hardware will never compatible with profilab.
Thanks for a reply
hrathke
Re: Pokeys 56U, USB version
Beitrag von hrathke » Samstag 28. Februar 2015, 22:59
Hello,
is there any reason for use the usb type from the board??? It works very well with the TCP type over Modbus.
regards
HR
TOURNEUR
Beitrag von TOURNEUR » Sonntag 1. März 2015, 15:53
hello, hrathke
Let me explain why ,
Not that I prefer Usb interface to Ethernet interface.
But I want to build a command box with multiple output connector where i could use on differ site, a test box if you prefer.
I destine ethernet pokeys to a definitive insttalation .
And mainly for the power requirement :
Pokeys 56U (USB) require 75 mA from the computer in standby mode
Pokeys 56E (Ethernet ) require an external 5V power which can load about 110 mA ,in standby and about 170 mA in activity
I need to incorporate a power supply with Lipo or Nimh batteries ...
I know it can be a little problem ,but 170 mA for a portable test system without any load ,it's so much.
Here my reason ...
Zurück zu „Weitere Geräte“
