Name of the standard librairies
nounours18200
Beitrag von nounours18200 » Donnerstag 1. Oktober 2020, 17:31
During the installation process, SPLAN installs the standard librairies in C:\ProgramData\splan70\BIBO folder, and these librairies are "lib1", "lib2", ...,"lib40".
In the Splan interface (left panel), these librairies have a name, probably depanding on the language, that represents what are the symbols included in the librairy. For exemple in a French interface, these names are "Transistors", "FET", etc...
I would like to change the filenames of the standard librairies : for example if "lib1" contains the transistors symbols, I would like to rename the "lib1" file in "transistors".
Is there a list somewhere of what are the symbols included in a given standard librairy ?
Thank you
Re: Name of the standard librairies
Beitrag von abacom » Montag 5. Oktober 2020, 08:04
in sPlan you can click with the RIGHT mousebutton into the library and then select the command "Info library page" (or in french "Information page librairie"). Here you can see which file is used for the library.
