Hi, now it works fine with only 2 tools, but when I connect another 2 addresses crazy.
In the attached diagram, maybe some wrong connection.
thank you
rs485 communication
rs485 communication
- 2012-11-20_173840.png (32.79 KiB) 5579 mal betrachtet
Re: rs485 communication
if I try to do a reset all communicate, maybe there is a problem as they are questioned?
I hope someone can help
thank you
thank you
Hi WoB I tried today everything worked perfectly, your suggestions are always valuable.
Thank you so much
Thank you so much
