How can I changed values when I send string on RS232?
Maxiq4
Beitrag von Maxiq4 » Freitag 31. Dezember 2010, 19:31
happy new year.
I want to send some string on rs232
like: ## freq:350//##duty:45$$
I can send it no problem,
But I wanna changed ONLY values when sending.
other charaters always same
example:
## freq:2345//##duty:67$$
## freq:1000//##duty:05$$
## freq:15//##duty:20$$
thank you
1.prj
(2.2 KiB) 572-mal heruntergeladen
Re: How can I changed values when I send string on RS232?
Beitrag von KAKTUS » Freitag 31. Dezember 2010, 21:53
Hi Maxiq4 ( from where did you come from?)
Don't use "Numeric Input" for strings.
Try this... Check settings in "$CS1"
addstringandsend.prj
(3.32 KiB) 570-mal heruntergeladen
Maxiq4
Beitrag von Maxiq4 » Sonntag 2. Januar 2011, 10:34
thanks again your interesting kaktus
how can I use slider or like volume potantiometer for input "changing string values, freq and dutys" ?
is it possible ?
Im from istanbul :)
Beitrag von KAKTUS » Sonntag 2. Januar 2011, 16:45
This question is to easy, do it yourself. (Replace the $Edt)
Whats about my example, is it working, did you test it with real Hardware?
Maxiq4
Beitrag von Maxiq4 » Sonntag 2. Januar 2011, 18:57
KAKTUS hat geschrieben:This question is to easy, do it yourself. (Replace the $Edt)
KAKTUS;
Im test it on the proteus not real, its working like.
its work but I need some addition,
when the first run, it must send one time last setting to rs232 (for exampe freq:150 duty:23)
Beitrag von KAKTUS » Sonntag 2. Januar 2011, 20:20
take PON ( Makes Reset at Power on) and connect it with COm String transmit. Put the needed String to the Input.s
Zurück zu „Thema RS232“
